Discuss Biasi Garda m90f 24s flue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi need to replace a flue on a biasi M90f 24s boiler. Does anyone know which flue fits?
Hi
It’s around 12 years old and it’s non condensing. The boiler has been capped because it looks like it’s got signs of spillage. The flue that is fitted is part number - 10999.0148.1 but it doesn’t look right. It looks like it’s for newer biasi boilers.
Thanks for your help
Who capped it ?
The guys capped it due to seeing daylight through the combustion chamber (he thinks it’s the wrong flue) is this correct? Is it normal to see daylight
Not normal to see daylight and cannot comment as if it is the wrong flue then at 12 years old you probably will not get the original. Unless it is the correct flue but fitted badly, in which case you can get the flue so fit a new one.
Reply to Biasi Garda m90f 24s flue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for a flue extender for a Protherm 60-80CI boiler. House is having external wall insulation and needs flue extending to avoid a new boiler just now. The boiler is GC no 41-047-66 and the flue extender had part no 230484. Anyone got one lying on their shelves? Thanks Paul 07761 103482
Oily smell from boiler recently before failed. Great plumber sorted though when opened external baffle at front of sealed flue the internal spring like tube lining outer insulation had all perished. Barn conversion with thick walls (763mm). Worcester Bosch say Flue Kits are obsolete and...
I’m getting water in my boiler which I think is coming from the flue (pictured). Is it likely that the issue is with the flue itself or the roof junction? I guess if it is the roof then I’m better asking a roofer rather than a heating engineer - right?
Hi. I believe this boiler can be changed to a system or combi. Does this mean the hot and cold tails have to be blanked off?? Also the horizontal flue does not come with self tappers compared to another brands I've installed in the past.. Im I right in saying it's almost like a pushfit? The...
We are considering buying a house which currently has a 20 year old Ideal Icos boiler, so we're factoring in replacing the boiler soon. Current boiler is on an external kitchen wall with the flue going straight out. However, it's positioned in between a door and the kitchen window, quite close...
