Discuss Thread sealants in the Plumbing Jobs | The Job-board area at PlumbersForums.net
magicno1
I have a few shower arms and concealed bath and basin spouts to do. Over the years I have done quite a few. Have been looking at Loctite thread sealants and was wondering if any of you use them and what number sealant you use. There seems to be loads of different number ones!
cheers all
Loc 577
[DLMURL="http://advancedadhesivesshop.co.uk/epages/10af3860-b08b-4deb-a7ad-c88fe8542800.sf/en_GB/?ObjectPath=/Shops/10af3860-b08b-4deb-a7ad-c88fe8542800/Products/7"]Loxeal 58-11 75ml - Advanced Adhesives[/DLMURL]
Looks good but trust loctight
Say`s you have to leave it 24hrs just like the 577, I never have 24hrs to wait.
Used to have a producer similar to loxseal called Cimberio. Same color and make up of Loctite. Brilliant stuff for tails in towel rails, garden taps etc. used it on a bib tap, screwed it in and left it 30 min and bingo! Can't get the stuff now.
Think I'll look at the 577.
Is the 577 ok on brass?
This has been discussed many times
It is loctite 577 for every threaded connection
On everything except plastic
Does anybody bother with the cleaner for 577 as shown in their video?
Nope if it's dirty just get a rag other than that I've done nothing special
Reply to Thread sealants in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm at the stage of my shower replacement where I have a new shower head to screw into the wall pipes. I tried it, turned on the shower, and find there are light leaks. Obviously I need to fix this so I got some Blue plumbers tape. Trouble is, the pipe doesn't stick out enough to easily wrap the...
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from. Why I think its I've used calipers on the threads and counted them, and the male end sticking out of the vessel is BSPT 3/4 with 14 threads per inch...
I have a waste pipe to install and it's giving this warning "Acetoxy sealants must not be used, as they may be detrimental to the plastic used in the manufacture of this gully." What exactly are the acetoxy sealants to be avoided? Be really grateful for any advice Thank you
Hi all, My partner and I recently bought a house and have been attempting to make the bathroom less fugly. I was removing the bath and shower taps to replace, but while removing the bath spout (which had no nut to undo), the threaded section of the pipe broke. I thought the bit that broke must...
Hi Just moved into a house and in process of renewing sealant around the shower cubicle. Feel free to skip to the bottom to get the question! There’s a gap (20mm in length & 3mm height) at the bottom of the frame (where it meets the shower tray) closest to the wall that appears to have been...
