Discuss Small grinder.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
turnpin
Subscribed
At the beginning of the year my old mini grinder give up the ghost.....got a couple of quid for Xmas what are you using...regards Turnpin
I use Makita 18v aswell only because all my kit is Makita so its easier, if you want a mains one i'd recommend Metabo for grinders
bosch if on mains and what ever bat platform your on there all about the same these days
Plus 1 for Makita. Everything from stainless steel cladding to marble tiles, used to have bosch but Makita is better build quality. Use a Hitachi 9" and that also quality tool.
Bought a Titan one 5 years ago from Screwfix. All my main battery tools are Makita but for a 4" mains angle grinder it is spot on and a shade over £20.
Just seen this and forgot to update picked up a ryobi from B&Q was £27 but paid £23 near on with. My 10% discount card...all good....regards Turnpin
Reactions: Dan
Did you also go on a Wednesday could of got a bit more off :)
The Bosch 10.8v mini grinder is a bit pricey but has been brilliant at cutting pipe in hard to reach places as well as bolt heads. I really didn't want another cordless format but there are some good tools in this range.
Yes! That grinder has been catching my eye and fluttering its eyelids but I've resisted so far...I want it!
What I'll do is I'll ponder it for a few months and then when it goes up in price I'll buy it, Thats what happend with a Makita planer, been at £84 for ages on Axminster and I've thought god thats cheap and as soon as I decide to buy it goes up to £98.00
I have this same grinder and it's brilliant bit of kit and even comes with a cutting disc for cutting wood which it does with ease. Worth a look if you don't have one
Metabo are said to be one of the best grinders you can buy.
I have the Metabo 240 volt 9" grinder.
I have a cordless 5" Hilti 22volt grinder, which is superb, but that costs a fortune to purchase.
I'm not a fan or grinders, I have a big Bosch and small Makita but hate using them unless I have to.
I had reason at home to cut through a metal I beam lintel in situ to remove it and had full face visor on an still got a red hot bur bounce off my neck.
Welcome to the metalworkers problems
Best one is when your welding above and a nice hot molten slag drips on your shoulder/ arm and the only time you notice it is when your on fire :D
Yes, I don't like the sparks as risk of fire and definitely will damage glass. But I find small cordless angle grinders invaluable and versatile for cutting roof tiles (even in situ) or cutting a clay sewer pipe, or grinding or cutting anything metal. It is a must have tool.
Reply to Small grinder.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello everyone, I have a Grundfos SoloLift2 WC1 on a toilet and since a few months the impeller keeps getting stuck. I was quite happy to unblock it myself using the service shaft above the motor and a long screwdriver, but it keeps happening roughly once every month. When stuck, it makes a...
H
I need some help and advice with a boiler issue. We have F29 and then F29 appearing on our new boiler. This happened after few days where water was dripping from the condensation pipe. Our regular gas engineer(who installed the boiler) was not available and will be in a couple of days. The...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just tried to turn on my CH for the first time this year as I have a number of guests coming for xmas dinner but even after an hour all the rads are stone...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
Hi, I’m looking to retrain as a gas engineer and do a new entrants gas course. I’m a bit concerned by the ‘on-job’ work experience/shadowing, as some course want to charge £1500 to pair you up with a qualified engineer. Some courses don’t offer pairing and suggest you find your own engineer to...
