Discuss Old Stop Tap Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MikeB
Apologies if this is in the wrong thread, it's my first post.
My stopcock is leaking around the spindle. I've watched a couple of youtube videos about repairing the leak but my tap doesn't seem to be the right type, it looks ancient and I can't see a gland nut on it. The tap spindle looks like it just goes in to the tap housing and if there is a nut it's corroded so much it's become one with the housing.
Is there any way to fix this easily or will the tap need replacing? It's in a really awkward place. Apologies for the poor photo, it's hard to get a good angle because of the positioning.
Can only guess without a better pic.
If it's going on to lead then it will be imperial and you won't get spare parts for it.
There looks like a bit of a hexagon shape behind the handle, is that not the gland nut?
It might be the gland nut but it's not hexagonal it's more like 10 or 12 sided and it's the same size as the housing below it.
That's the (Nut) that removes the complete workings of the tap, if you can turn off the water from outside, & you can get the old tap apart, if your lucky the inner parts from a new stopcock will be a straight change over
Well I showed it to the landlord and he didn't seem concerned. Said he'd call his plumber mate but told me not to "hold my breath" and expect anything. In the meantime I've stuck some plumbers epoxy around the leak and that seems to have helped a bit.
At a guess from your photo, I'm going to say that is the gland nut and that instead of pushing the stuffing directly, it sits on top of a collar that pushes the stuffing. Posh or what? Old stuffing could be asbestos string type and, whatever type it is, possibly clogged with limescale so won't work properly. Sometimes it's easier to just laugh off the existing stopcock and fit a new quarter-turn valve downstream of it.
Personally I wouldn't worry - it'll probably seize and then it won't leak. You won't have a stopcock but if your landlord can't be bothered to maintain his property it's his house that will get flooded (and you'd have a counterclaim if your belongings got wet). I'd just make him aware in writing and let him get on with it. Under the ?1985 Housing Act the landlord is obliged to maintain the structure of the property, so ball's in his court - I wouldn't even touch it apart from turning it on and off as if it goes wrong you become responsible by meddling.
Reply to Old Stop Tap Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I cannot isolate my toilet water supply for a quick-fix, as the valve/tap is buried beneath tiling by whoever built the place. All other taps in the flat just isolate the kitchen. Is the green switch next to my water meter in this blurry photo a stopcock? It is underwater because there seems...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then drip slowly after that...........i put a bucket under the shower head to collect the water for 26 hours the first time.............then 19 hours the...
quality product wanted, my 1/4 turn kitchen sink tap inserts need replacing and i am looking for ones with a spindle gland nut, rather than a circlip which previous experiance says won't last five minutes. as the circlip either weakens or wears out. none of the ironmongery supermarkets appear...
Pete Williams
Hi, as you can see pictured I have a stopcock without a packing gland. Over the past few days my cistern inlet was suffering from an airlock and it was hammering constantly after filling. I turned off this stopcock, drained all the pipes, turned the taps back off and then let the water back...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
