- Messages
- 5,167
Morning all. I hope you're all well. Wow has it been a long time since being on here. Work and family life is nuts at the moment. I hope you're all.busy as well (if that's what you want ).
I need some advice on running this basin waste. The spec shows it going into the toilet pan connector ( see picture attached). I know this isn't a good method but there are no other choices as the cast stack runs into an extension roof and so to get to it I would need to remove the tiles etc. Now I have not been able to find a pan connector with a boss on the side, only on the top. So is there anything anyone knows of? I will put a hep valve on the basin waste.
I cannot load a photo as it is not giving me a file option. Just asking for a url. Anyone, it is just a bent pan connector going into a collar of a cast pipe.
Thanks guys.
Thanks guys.
