Discuss Vent pipe on expansion tank. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have inherited a half cocked system which am now trying to sort. Attached is a photo of the setup. well part of it. Am just being certain what the 2 pipes on the top of the air seperator are.Think I am correct in saying the 22mm pipe is the vent and the 15mm pipe is the feed/expansion one.
Is it normal to have a seperator?
Yes and I know the soldering looks dire even I can do better than that!
15 mm is the feed from the f and e tank
And yes 22mm is the safety vent
There we'll know for getting blocked (air separator)
The 15mm pipe from the F/E tank has a gate valve fitted is this a good idea or not as I suppose could be accidently closed.
It's ok just label it if your worried
Yes it shouldnt be there , just take the wheel off , no dramas
Reply to Vent pipe on expansion tank. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
