Discuss paint for copper pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
is there a paint or spray that I can use on copper pipes? I would like to paint copper pipe on radiator (the bit that sticks upwards with the white cap on top) white. is this possible?Many thanks!
Do you mean the trv ? If yes it's not a very good idea to pain that as it moves
You can paint the white pointy cap (lockshield)
sorry - it's the little copper pipe?
I have heard it can be painted to match the radiator.....
Not painting the caps or anything just thinking about the copper pipe
Consider using snap-on pipe covers instead of messing around with paint. Just replace them each time you redecorate to keep them looking smart.
RADSNAPS Radiator Pipe Cover - White - Pipe | BES.co.uk
Yes your fine painting just the pipes
many thanks - really helpful - can use use white emulsion, acrylic primer or duluxe paint? The snap-on covers sound great though
I would say duluxe or emulsion would be fine
On copper you should really use an etching primer first , you may find a small tin at B+Q. However most people just paint them with whatever is in the garage .
My wifes pal paints radiators with emulsion no primer , just paints them , never seen paint crack , craze, chip , etc they still look ok lol
Reply to paint for copper pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
