Discuss Automatic Air Vents - How Many are required? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys,
My son has just had a his plumbing done about a year ago and one of the air vents seems to be bubbling/leaking up.
I have attached some pictures, I can see a total of 3 air vents, flow and return near the boiler hve one each and there is one on the return on the return pipe near the cylinder.
does this sound about right or has he guessed the work and stuck one every where?
I'm thinking of closing it off if not required...
In my house i only see 2.
Thanks!
The site owner doesn`t like links to other forums ;)
EDIT,
And I don`t like having a complete post removed for no good reason.
Who was it and tell me why via a pm if you prefer to stay in the shadows.
Screw the black caps back down only need opening if draining and filling the system
The purpose of an Auto air vent is to vent high points when air is likely to accumulate.
The location of the boiler 2 is wrong and won't do much except when refilling the system.
As per Shaun, close the boiler ones off either with the black cap on top or the valves immediately below.
The one on the cylinder return isn't going to achieve anything either.
Tidy pipework. But it's a shame the vents aren't at the top of the flow and return!
thanks for the replies.
Where should have the cylinder have been fitted or was it not required as it too low already?
Cowboy plumber he was in this case!
Be fine where they are but the heating ones should of been at the heights point
Reply to Automatic Air Vents - How Many are required? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dear professionals, could someone kindly advise on per below issue, please let me know if more pictures or details needed. I think my Auto Air Vent is now leaking. A little background on the boiler – installed a year ago in Feb, Valiant Heat only boiler Eco Tec plus 424, plus new pump. The leak...
Hi, I'm new to the forum and just some background on myself. I have 4 years experience as a plumber but haven't worked in the trade in 15 years. I would say my overall knowledge is not great as I did most of the 4 years working on rinse and repeat estates of houses. I was also quite young and...
Hi, I’m replacing my old Honeywell Smartfit system on a oil fired gravity-fed system in a bungalow. I’ve read conflicting advice on gravity fed systems requiring an AAV, unless in a bungalow to aid bleeding on first fill? One AAV is in the loft on - what I think - is the boiler return pipe...
I've air tested pipework for years, typically 4 bar for 30 minutes. I've never had an issue with any pipework that has passed that test, occasionally you get a small leak from the air test typically old cap ends/scratched pipe which shows up easily on the test without having to inspect anything...
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The issue is quite simple to repair not sure why any one of the 2 plumbers could not fix it. Why am I paying for cover. The auto air vents in part of the...
