Discuss What do I need to cap these pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
Please forgive my ignorance but I was hoping someone could let me know what I need to cap these two pipes so I can disconnect my tap and toilet from the water supply... the toilet one has a screw on it - is that for isolating the connection?
Many thanks!
Ross
Turn the screwed one to quarter to three . In otherwords horizontal . The other pic needs a 15mm cap but with a fibre washer in .
Personally I would isolate the water and use a 15mm insert and pushfit cap after the isolation valve on the toilet and remove the coupler from the bottom union on the tap connection and use a 15mm compression cap
And make sure the insert is inside the pipe for the tap
Reply to What do I need to cap these pipes? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
