Discuss Brain Teasers - which one will fill first? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dan
Administrator
Staff member
Admin
F, 3 and I have no idea, so I will say the same.
Nice to hear from you though @Dan
Edit due to being an idiot and not looking at the diagram properly
edit, - I had another look and nearly reversed my answer!
So much can be missed! :p
G and 4 if the tap is running slowly, A and 1 if it is running fast. Slightly down on the left due to the weight of the thread and the ping-pong ball although the question setter probably intended these to be negligible, in which case no change.
Reply to Brain Teasers - which one will fill first? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Water keeps filling up my home water tank from the output valve at the bottom of the tank and not from the top of the tank Water keeps pouring in from the output valve and won't stop, making the tank overflow 24/24 At first we thought it was the input valve at the top but after inspection we...
Hello all, I have just joined, after being pushed into some DIY plumbing. Here is my first plumbing DIY effort. I had a cistern lever that didn't flush properly, and had become corroded and unsightly. I figured I'd get a plumber in to do it (after a couple of years apologising to guests for...
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is switched on before it stops. There is a sink nearby, sometimes if we switch that on slowly before turning on the shower then the shower doesn't make a...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use a push fit tap connector instead which will give me more flexibility in fitting?
A little brain teaser for you chaps had a call yesterday my boilers not working ? see if you can spot what I found
