Discuss Heating / hotwater controller replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all , can you recommend a simple to use and reasonably priced controller for a Y plan system please , friend has an antiquated one that needs replacing ( cant see the make)
cheers Howy
Drayton lifestyle
cheers Howy
Hi howy,
You could install a Honeywell controler
Reply to Heating / hotwater controller replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
