Discuss Hi! My nickname is Glow and am a new member! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just had a new Worcester Bosch gas boiler fitted i.e. not combi by a professional firm! However I have noticed that when I put the heating on, two of my radiators in my living room seem to each have cold spots one side! None of the other six radiators in my house have any cold spots! I have tried bleeding them but does not seem to make any difference! Appreciate any advice on this! Thanks
Turn half the good ones off do the problem two heat up evenly?
Welcome along matey. Was the system flushed? Could just be an air lock. If you have trv’s on the rads turn them off put the heating on and open one of the ones that is not working to see if it clears it then do the other one.
Hello Glow,
Welcome along.
You could try shutting all rads which are heating in full to force the heat through the rads which have cold spots.
Reply to Hi! My nickname is Glow and am a new member! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
