Discuss Pan-connector fitting to soilpipe query. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys
Just a quickie re the WC pan-connector below. I guess this must be a solvent-weld fit to the soilpipe? It needs replacing so I am intending to cut the soilpipe at the joint and fit a conventional connector where the finned seal goes inside the soilpipe. Anything wrong with this idea?
Thanks for any tips.
Nope your fine normally cut just after the white collar but as long as your on to 110mm pipe your fine
True, depends if you can get one the right length, a lots of merchants don't stock them.
Cut to your own length it's the only one I use even if it's short just cut to what ever I need
Just looked at them and they look good. The mc alpine ones I've used in the past have been white rubbers on pan end and never liked the fit. I guess it's what we get used to using.
them ones i linked need some lube to push them on :D
Can't go wrong with MC alpine tried and tested it's the no name makes that are crap.. is that your nickname or are you a urine extracter
Reply to Pan-connector fitting to soilpipe query. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
