Discuss Can I turn water off at mains and leave heating on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
Sorry for a very basic question but I wanted to double check, I have a Maxol Supacombi HE28 boiler in the kitchen and as I'm away for a couple of days wondered if I could turn the water supply off at the mains but leave the central heating turned on?
Thanks in advance.
Reply to Can I turn water off at mains and leave heating on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in kitchen only Stopcock in kitchen wall panel turns off cold water supply in kitchen only Red gate valve in airing cupboard next to bathroom turns off...
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some times the flame failure light comes on but it ignites again after a few seconds. The plumber has changed a couple of sensors on the boiler and checked...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn the water off to avoid potential catastrophic damage. When I go away I have always tended to turn ours off, that's typically anything from a couple of...
Hi I’m new here and don’t know a thing about plumbing so be gentle on me as I am also going to ask a possible dumb question, this summer I turned of the ”heating“ on the Drayton box and turned thermostat to zero but obviously had to keep the hot water on as I do every summer but I noticed the...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to my toilet off is that a correct set up? Because it didn't used to before the stop valve in airing cupboard only turned off the cold water supply to...
