Discuss No power at Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MarkAqua
Not too clued up on domestic control systems, so was wanting a bit of advice,
Potterton EP2001 programmer, CH & HW
MID postion valve
Honeywell T6360 room stat
I've got no power coming into their room stat
The geezer has replaced the stat but didn't make a difference. Hence calling me.
Hot water works fine,
I've belled the wires from stat to wiring center and all have continuity.
Can't seem to get a voltage reading out of the top of programmer when Heating is on and it is coming up with random lines on the display.
Oh and the custard put a link between white and orange wires for mid position valve and heating worked constant (no control on thermostat)
I'll attach pictures
I am thinking it's the programmer at fault as I've checked the wiring and terminals and all is good everywhere.
Cheers for help lads
pop the prog off and insert a link wire from mains in to heating on
if that works progs at fault
but the screens gone as its suppose to show the time
Reply to No power at Thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
