Discuss Toilet flush no longer working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, could I get some advice about a toilet flush which is no longer working? The flushing mechanism seems to be in one piece, the handle is solid and the plunger that leads into the toilet flushing mechanism is intact and raises when I use the lever. However on raising the plunger only the smallest amount of water is moved through the syphon. A full flush doesn't catch.
What could be the problem here? And what can I do to fix it?
Thanks in advance!
Hard to c from your picture. Is d cistern full of water. If so I'd say the siphon is faulty
Yea new siphon
Either turbo 88 or fluidmaster adjustable ones
Thanks for these replies everyone. It was the siphon - the diaphragm was shredded, so was pulling up very little water.
Replaced the whole thing with a dudley turbo 88. Works great. Thanks for the advice!
Glad you sorted it and thanks for the update
Reply to Toilet flush no longer working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
