Discuss Setting pump speed for UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've just had a new UFH system fitted with a Reliance Thermomix control pack, which incorporates a UPM3 Auto pump. I'm wondering how you arrive at the best setting for the pump - it is providing flow to 6 separate pipe runs, designed as two zones controlled by wireless thermostats. I feel it would be best to set it to Proportional Pressure Auto Adapt mode - but I'm no expert and would welcome advice.
Roger
I have a feeling that constant pressure autoadapt is recommended for UFH?
Thanks for the advice - however since posting I think I have another problem as all the pump indicator lights have gone out and it is not running. Pressing the indicator button won't produce any lights so it looks as though the new pump has failed after just 12 hours of running. Time to call the installer back, I think.
Edit - pump is OK - it was a communication issue with the wireless thermostat. I've switched the pump to constant pressure autoadapt and will see how it goes, thanks.
Reply to Setting pump speed for UFH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
