Discuss This week's "Who the hell fitted that?".... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sid Viscous
Subscribed
Found this in the kitchen of quite a posh Victorian house....
I love the idea of some bloke standing to admire his work thinking 'Oh yeah!' o_O
i
Diy maybe ?
That drain off is classic
"Hello, I'd like a radiator moved in my nice new kitchen, all I ask is that you make it look as ugly as you can and if you could fit the drain cock upside down, that would be nice"
The thing is, there are plenty of people who would look at that and see absolutely nothing wrong with it.
Why exactly can't you fit this rad vertically ?
I've seen people fit 3" ogee architrave back to front with the wide edge nearest the door because they thought it looked " better ".
Better than what exactly, my dogs a**e perhaps.
Well even the present Mrs Viscous could see that something wasn't right.....
They looked like standard rad brackets. I'm guessing the pipework is what's stopping it all sliding off.... or No-nails/Fixall ;)
I saw one of those. Looked like the homeowner had made his own brackets from sheet aluminium. Although I did eventually fit the replacement, I wasn't the one doing the removal, so I didn't get to admire them. In 'my' case, though, the wall section was very narrow and I doubt it would have been easy (or possible) to obtain a satisfactory solution without this kind of alternative approach. In your case, though, WHY?
'Prat' is all that springs to mind.
Oh now 'builder' has crept in too...
Obvs a person who ticks boxes (needs this that and something else) but obviously has no idea of how things work or why they are fitted so does it spectacularly wrong...
As it happens Dave you may be bang on the money. The lady of the house said they bought it from a builder who'd converted it back from HMO to single dwelling.....
Also in the local area, found this in the entrance to a city pub. I wasn't even drinking as I was on driver duty!
Ah, the old days when breaking the phial on a spirit level meant replacing the phial, not a whole new level of waste.
Reply to This week's "Who the hell fitted that?".... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
First of all, apologies, it seems this topic has been posted but don't believe my specific issue is covered. So been living in my Victorian house for almost 10 years, no issues. Have 2 bathrooms, 2 loos that all go to a large underground soakaway, I believe. I can only see one soil vent pipe...
Hi Guys, My chimney failed the test so I need to install a flue liner for my Gazco Stockton gas fire. It was over a year ago when the engineer condemned the chimney and I remember him also saying something about it needing some sort of box fitted into the fire recess but I can't remember the...
Installed a victorian plumb shower valve and tested last night, on and off no problem. Tested againg tonight and it came on but wont switch off. Contacted victorian plumb and have to wait up to 72 hours for a reply. Any ideas on what I can try as weve been without a shower for over a week now...
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This was all then covered with dot and dab. Shown in the picture, red arrow. So the only thing visible now is a round pipe from the wall. We are yet to fit...
