Discuss Cannot find toilet seats with 270mm gap between hinges? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I hope you can help please?
I am having real difficulty finding soft close D-shape toilet seats which accommodate a gap of 270mm between the hinge screws. I have checked on plumbing sites, Amazon, eBay with no joy - even the adjustable ones just don't seem to allow a gap that wide.
Any ideas? Any help would be greatly appreciated.
thanks!
What’s the make? I got caught with a Duravit pan the other day. ONLY their seat fits at £115 a go
in my last house git caught with a sort circular seat £95.00 even with discount
thanks!
Hi Dan - check this one, it might fit?
https://www.amazon.co.uk/designed-Duravit-standard-Manufactured-plastics/dp/B008OHTVGU
Half the time it's cheaper to change the whole toilet to a different style if you can
Thanks for your help!
It is indeed a Duravit. They’re ridiculously expensive. Eek!
Don’t fall into the trap my customer did and try and buy various one size fits all seats
Reply to Cannot find toilet seats with 270mm gap between hinges? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi, as the title suggests i need help finding this type of toilet seat, i ordered one but completely forgot to check distance between fittings and it didn't fit. The distance between the fittings for the toilet is 260mm and its for a wall hung toilet. i can't seem to find anything similiar.
R
Hi Looking for a toilet seat (D shaped) with the distance between hinges of 270mm. Width of seat is about 410mm and length 440mm Any suggestions would be welcome. The toilet unit is Ideal Standard and is over 20 years old. It is is great condition, but the toilet lid is broken as a builder...
RajendraH
R
Hello All, Was looking for some innovative ideas from you all.😊 I’m renovating a bathroom in a flat. The soil, hot & cold water pipe runs stops me from butting the new toilet cisten flush to the wall. I was hoping to use a flexible waste to help me get closer but the pipes stop this option. The...
M
Hi, I'm trying to find a supplier of replacement hinges for an Armitage Shanks Bakasan toilet seat. If someone has replaced this hinge and knows of any 100% compatible replacement set in chrome or white, I would appreciate your advice. This seat i'm looking at is perfectly servicable, but the...
C
Any advice would be very welcome. We need to replace our toilet seat. The toilet and seat have no makes on them. On measurements it’s 34 width and 40 length d shape. I have been looking everywhere and can not find this size toilet seat at all. I have found one that looks very similar called...
Deleted member 120897
