Discuss Indirect cylinder heating problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Boiler has 28mm pipes to indirect cylinder gravity feed. Pipe exit from boiler is hot (boiler stat no5). Hot water cylinder not hot enough, boiler running 24 hours continuously. Problem only started, previously piping hot. Can only think there is a blockage or restriction in pipe work, but seems unusual in large bore copper. Any ideas?
Have you drained the system down ?
Header tank 1/3 full of water ?
Things that need checked are, -
Is there a few inches water in expansion and feed tank?
Is there water at top connection to coil?
Is there a blockage in the feed pipe?
As B4 small tank in loft is empty and water level in pipes is to low to let it gravitate
The older ballvalves that have brass pistons inside them will tend to seize up easily on heating tanks, as the valve rarely needs to replenish water
I agree entirely, whats better to fit is a modern foreign valve that will fail and never shut off after a couple of years, that way it will need replacing again lol
Check emitters are all okay might need a tweek of a bleed after topping up the f&e.
Reply to Indirect cylinder heating problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
