Discuss Gloworm betacom 24c not staying lit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Selectsands
Help please, after trying to discourage my customer from moving this old boiler, I dutifully did and once she fired back up, the burner lit for about five seconds then out and the flame flashing indicator starts flashing... is this a problem with something I may have done or the pressure switch, gas valve... ???
Cheers in advance
Anthony
What testing have you done ?
Hi guys, yes I’m gas safe registered, I’ve read a number of your posts so know you’re both very knowledgeable.
I checked the gas supply, that the fan works, the pump runs, the system pressure is 1.5 bar, the condensate trap and pipe isn’t blocked..
what am I missing
Cheers
what am I missing
Cheers
What comes after the fan in the ignition sequence
The fan proves the differential switch and then ignition , I guess the boiler is staying in the low burner state and the gas valve is not opening fully... flame rectification??
Does it stay lit?
Give admin your gas safe number mate. They can then give you he correct access to the areas you need.
Morning guys, apologies the missed said that if I didn’t stop working there would be trouble!! It only seemed to stay alighted for a few seconds... then out and then flashing flame or gas failure light flashes... how do I give admin my gas number please
Did wonder if that might be it last night, maybe just a case of checking it’s not got dirty and needs a wipe...
Worth checking also if it lights and then goes out what's that telling you?
Also pm me your gs number will get it sorted for you
Good call , when I moved it and it was lying on its back it may have washed some dirt about in the trap... I’m message my details to you Shaun , thanks
Evening Shaun , I believe I messaged you but haven’t heard anything, did I send it correctly? I’ve been working on a new build site today... jeez they couldn’t organise a fart in a baked bean factory!!
Will look now haven't been on much today due to work constraints
Reply to Gloworm betacom 24c not staying lit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello forum members thanks for the welcome. This is my first post. I have a Gloworm 15hxi. Its been a really good reliable boiler. I am doing some decorating in a bedroom so had to take a radiator off. When I refilled the system again everything was ok overnight but the next day there had been...
Hello My trusty Vaillant 242 EH is having some issues. It has developed an issue when firing up the burner. The fault is seen with the hot water and central heating. When it operates it takes anything from one to several attempts to light and when it takes too many the lockout circuit is...
I am trying to troubleshoot a Baxi Luna 3 Combi boiler 8 years old, that is not making any hot water. It is in a customers second home, and receives little usage. Over 2 days, hot water was getting less hot, until now none at all. When I call for heat, and the unit fires fine. There are no...
6K
N
Thanks in advance for any advice. We have a Lefroy Brooks XO concealed thermostatic valve shower and Worcester Heatslave 20/25 combi oil fired boiler. We moved into this property 4 months ago and from day 1, our shower has not been able to maintain temperature. It starts off hot, and after a...
Nathalie
N
Hello I'm seeking helpwith a central heating problem please. It's a fully pumped system with a diverter valve for cylinder / rads and has an open header tank. Potterton Prima 40B. The first sign of trouble was yesterday evening, no hot water. The hot water and radiators had been ok earlier in...
