Discuss Olive Cutter or puller in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi.
I need to remove this shower valve and I'm a little worried about causing damage to any pipe work.
What's the process and how do I blank off the pipes whilst tanking the shower area.
I can decide if a speedfit cap would be best, or assuming there is and olive on the each of the pipes, just attach an isolation valve.
What can I expect to find?
If there is an olive will I need to replace it when reinstall the same valve, or can I leave it on?
Thanks.
Really worried about this stage of the job.
Undo the nut cloest to the wall and use a 15mm compression cap end
As above blank off with the 1/2"part of a 15mm compression cap . cheers kop
Compression cap?
Will I need to remove the olive upon re-installation? If so, what's the best method
Are you keeping the existing shower or changing it ?
Reply to Olive Cutter or puller in the Plumbing Jobs | The Job-board area at PlumbersForums.net
