Discuss Height of new boiler .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Murdoch
Res.Electrician
Chaps,
I'm a spark and working on a refit ..... the GSE is going to put the new boiler on the wall very close to the floor - is this OK?
Never seen one low on a floor before.
If it's to M.I's then it's ok. Going to be a right tw@t to work on in future though, accessing valves etc. Sounds like he's a F.I.F.O merchant!
Normally most require 4-6" below the boiler
Any reason why he's fitted it so low ?
Can't be under a window, unless he can achieve the correct clearance.
^^ it’s going in on Friday ..... when I’m back onsite I will take some snaps and post them
Reply to Height of new boiler .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
