Discuss Wet vacuum on the market recommended in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
I'm looking for a wet vac that can clean out sanflos.
I have the blue Henry (Charles)
It's average, dies the job but wouldn't buy another
Mines the Wickes one , sound for the money , not sure about clearing sanis with it though lol .
Rpm is your man for that bud, i use a Draper one with stainless steel cylinder to collect the nasties it has a foam filter over the motor so dont think i would use it for --it collection . kop
wicks -ÂŁ40 had a few years, still going and it's a half pint so it fits in my van!
Got one from Tradepoint (B n Q) for ÂŁ25... done a great job so far, although not tested with Saniflo's...
Saniflo's have to cope with allsorts.... underpants one time in my experience..... :eek::mad::(
Reply to Wet vacuum on the market recommended in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello there all, I care for my disabled mum and her wet room ceiling has developed small speckles of black mould. I plan to remove the black mould and then paint the ceiling voer with a decent anti-mould ceiling paint. Can anyone recommend a decent paint brand? I know of Ronseal and Zinsser but...
So my hot water tank is barely 3 years old and a recent service check tells me the tempering valve is on the way out It's a Hydroboss brand from Tradelink and I'm keen not to replace crap with crap So what are the best brands of valves on the market ? The plumber recommended AVG
Hi All, Looking for a recommendation for a heat only boiler to replace my 30yrs old ideal boiler. Any makes you would recommend and any to avoid? Thanks
Hi, Can any one help, I'm in Shrewsbury and looking for a plumber to do the wet system on a new rayburn 355sfw, radiators only no hot water required, Chimney and heatas side of things are sorted, so just the plumbing. Thanks
I'm at the stage of my shower replacement where I have a new shower head to screw into the wall pipes. I tried it, turned on the shower, and find there are light leaks. Obviously I need to fix this so I got some Blue plumbers tape. Trouble is, the pipe doesn't stick out enough to easily wrap the...
