Discuss Leaking shower pod/wall hung shower unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jones82
Came across this unusual shower unit.
Sirrus shower, leaking from the hoses on the back, which are perishing.
They are pushed onto spigots then secured using jubilees.
Anyone know where I can get some new hoses?
RJ Pryces lowestoft keep it you can buy online with them and stainless jubilee clips . very poor design but hey ho cheers kop
You can buy that hose any size from any pneumatic supplier such as Thorite cheap as chips
I buy it by the metre on ebay. Useful hose for poweflushing, you can see air and muck in the flow, buy different diameters.
Reply to Leaking shower pod/wall hung shower unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
Hi all. Shower is leaking into downstairs when water is being aimed at wall . All sealant has been redone on outside and between shower tray and wall at the bottom on inside , can’t spot any leakages here. It runs down the wall downstairs beneath shower in lines , when water is sprayed at the...
I've attempted to replace the shower hose from our Aqualisa Lumi electric shower unit. The new hose is badly leaking water out from the connection point and when I reattach the old hose it is now leaking too! Both have been tried with new washers and are as hand tight as they can go (wasn't a...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
