Discuss Speed fit tap connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can I ask people thoughts on speedfit tap connectors they are ment to only need to be hand tightened. Getting less and less keen on fibre washer connections on taps and toilet fill valves now. Rubber washers seem to seal so much better.
I think the rubber connections are definitely better than fibre but don’t like the idea of pushfit. If pushfit then hep2o
work well, used them for a while and they make life just that bit easier never had a problem with them leaking.
Must admit a favorite of mine as well great on plastic inlet valves on cistern regards Turnpin
I don’t use the plastic fittings and tbh I just remove them (if add ons) where I have to replace a cistern or taps for examples.
I use soldered tap connectors, but I replace the fibre washers with the Hep flat rubber washers.
That’s also a good so solution with being rubber washer :) I think by the time our solder all together isn’t it quicker to use the other fitting? I didn’t come across one which was leaking due to low quality materials if it’s leaked then due to not tighten it
Yes definitely can’t beat the speed to install a Speedfit tap connector - 2 seconds compared with a couple minutes to have a copper tap fitting prepared and soldered plus then the time to tighten it up.
I haven’t seen a Speedfit tap fitting leaking yet, but they are delicate.
I know that on copper plumbing a lot of plumbers prefer to use a Speedfit connection to toilet cisterns.
I shall remain old fashioned though
Thanks tried a hep2O flat rubber washer on a copper 62. Seems a good fit. Just to confirm as tight as can with hand only on the speed fit connectors?
I can vouch for the quality and reliability of John Guest fittings. I use them in the training workshop that I run. I use the JG fittings because they are demountable without tools, I can reuse them so many times which saves on my course budget. It's easy to replace individual parts in them. Most importantly I have had the same JG pushfit elbow on my pressure tester since this time last year. It gets mounted, pressure tested and demounted and reused many times a week and has not failed me yet. Although I will use copper wherever possible and don't like plastic in general I do trust the JG range.
Reply to Speed fit tap connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks Really daft question here but what tap connectors are you all using? I’ve picked up a couple of end feed with fibre washers today and the washers didn’t fit. Just would not fit over the little spigot that sits just inside the tap. I ended up using different washers which were baggy...
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe using compression: https://www.NoLinkingToThis/p/flomasta-compression-straight-tap-connector-15mm-x-1-2-/58294 If not, please could someone let me know...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use a push fit tap connector instead which will give me more flexibility in fitting?
Hey, I've got a leaking toilet and I need to replace the filling valve device which is a Geberit 810.L3 Type 340 with a 1/2" connector. Problem I've got is the connection under the tank (image attached). The top plastic nut (yellow) is only to hold the fill valve in place - I can undo it by...
I had a plumber in to replace my old pan connector as it was leaking due to the wax deteriorating. Now when this toilet clogs up (which is a separate issue), it leaks from somewhere at the back. I can't tell where it's from but can tell for sure it's not from the water inlet or the toilet side...
