Discuss Please help me figure this out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in East London in a victorian mews house. In the past few days I've noticed an odd sound, as if the water is running somewhere in the house, followed by a 'clunk' noise intermittently. It happens every 20-40 mins and lasts 3-5 seconds. This happens when the house is idle, i.e, even when no taps / appliances are used.
The 'clunk' noise is something I am familiar with, in the past this happened when we had high water pressure, and switched a tap on and off. To fix this, we turned the water pressure down – the clunk noise stopped and the tap felt 'softer'.
Other things that may help with figuring this out (maybe):
When taking a shower, the water pressure sometimes drops for a few seconds. Sometimes it is only a drop in pressure, sometimes the temperature change as well.
Also in the past couple of months our kitchen mixer tap had been 'sticky', ie difficult to open and close, but we didn't get around to fixing it yet.
Any ideas what this could be? It's not a bit problem obviously but worried it would turn out to be later!
Many thanks,
T
My partner tested the toilets and you are right! it seems that something is wrong with our downstairs bathroom.
Thank you sooooooo much for your help!
Reply to Please help me figure this out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I can sometimes recover the usual water pressure by turning the hot and cold water taps on and off which seems very strange to me. There is no problem...
We have recently had water hammer issues. Plumbers have installed an arrestor near our kitchen sink and a device in the toilet cistern to slow water shut off. Worked for a bit, but hammer returned. This morning, while the toilet was refilling and the shower was on, there was a loud thud that...
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is switched on before it stops. There is a sink nearby, sometimes if we switch that on slowly before turning on the shower then the shower doesn't make a...
R
I just had installed a Navien NPE-2 with built in recirculator pump. I have a dedicated return line. The check valve for the recirc is built into the unit; a spring check valve was placed on the cold line (per the manual) after which there is an expansion tank (on the cold line) in a T junction...
Rogelio
R
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
