Discuss Can I Swage Gas Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello new here, can I swag gas pipe instead of using a fitting?
Are u gas safe registered ?
Pb plumbers work
Decent fitter pb, almost as good as me. He loves to promote the latest gear tho. Swear he's sponsored by the sheer amount of kit he has
He is
Just out of interest - off topic.
What are your copper tube wall thicknesses?
We measure our pipe OD.
1/2" - 0.91 mm
3/4" - 1.02 mm
1" - 1.22 mm
We always expand copper ( swage ) and have never had too many issues
I suppose expanding (stretching) the pipe for making it into a socket is no different than bending pipes with a bending machine, as still being stretched and made thinner.
But what is the cost of 22mm end feed connectors? Almost nothing.
I see one slight advantage to swage pipes that are rising vertical, - you have a vertical top joint only to solder and the solder will flow down easy, as opposed to also having a joint to solder from the bottom.
If you are counting how much solder wire and flux you are saving by using a swage, then you must be on a very tight price
1/2" - 0.91 mm
3/4" - 1.02 mm
1" - 1.22 mm
I think 15mm is 0.7, and 0.9 for 22mm, so a bit thinner than your stuff. I'd be tempted to do it on water (it looks good), but only if I could get a squeeze-operated expander. Seen one in books, but not for sale. Can't be bothered to have to start hitting an expander with a hammer while supporting the pipe somewhow.
Swage pipe for plumbing and heating. If the copper is good quality then a swaged joint is fine and IMHO looks good. If you have a bender, springs internal and external with different shaped knees to get different bends, and swaging tool then some quite dandy pipework can be achieved. Mind you I am getting too old to do 22mm too much this way !
Reply to Can I Swage Gas Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes behind the electrical CU which I'm due to have replaced soon. We are looking to cut the old pipe out, but trying to working out what material it's...
I know no one really does. But technically why should we use bonding clamps when we cut a section of gas or water pipes out? Thanks.
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old people. Out here competence and integrity is harder to come by in a worker, in fact it's hard to find workers at all where we are in the countryside...
Hi, I have recently moved in to a house and in one of the kitchen units where I want to put a intergrated freezer there is a small pipe coming out of the wall. Assuming it's a old gas pipe for the cooker that's been capped as the kitchen no longer requires it. Can this be removed by a...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use a push fit tap connector instead which will give me more flexibility in fitting?
