Discuss 1 m of 5inch twin wall needed to finish a project off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rob Foster
I will happily pay and collect in N/W around merseyside Thanks Rob Foster
Hi Rob, if you wish to PM me what brand you require i can probably help i work for a solid fuel supplier and have access to midtherm, selkirk, convasa, negarra, dinak etc. I'm no were near you locally but we can deliver without any problem.
hey look you thank you but ur miles away i will collect
or arrange dhl we have an account
Like i say if you'd like to tell me brand i can get you a price delivered if we have access to it. Its normally ÂŁ10.00 postage for 1mtr of flue, more than welcome to arrange your own courier but obviously any damages etc they are your responsibility rather than ours as such.
cheers my dear as we used to say in zomerset
No problem, we say that as far down as Cornwall too! i've got no internet at home at the moment. Ill pick this back up Thursday when i'm back in the office. Let me know what you need by then or attach a couple of pictures of the end fittings and i can probably i.d it for you and ill sort a price.
Cheers
Mark
Cheers
Mark
dyreckly is that wright
Reply to 1 m of 5inch twin wall needed to finish a project off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, We have a small bathroom, which currently has the toilet on the outside wall, and the sink on the inside wall. What are the chances/challenges of switching this round, i.e., fitting the toilet to the inside wall? Here's what I mean: So toilet would be hung from the stud wall, with...
2K
We had the bathrooms replaced when we moved in 2 years ago. This involved 2x bathrooms and 1x WC. Within the first few weeks, we noticed leaking from the en-suite down into the reception room and the fitter promptly came and repaired it, it was something to do with the area under the sink. We...
Hi I have a system boiler (Worcester Bosch). There is a Magnaclean filter fitted, which I assumed was just on the central heating. Heating was turned on a couple of days ago and the pressure on the boiler has been dropping. Last night I made sure the heating side was turned off, wrapped...
1K
Deleted member 120897
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve and Y strainer to old cylinder, reduce to 15 mm and to pump flexi and reconnect existing hot distributing pipe. Repair shelf in AC and fit twin...
5K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
