Discuss 1 or 2 mill insurance? in the Insurance for Plumbers area at UKPlumbersForums.co.uk.
Thread Status:
  1. cure1973
    cure1973 Guest
    Hi everyone
    Just wondered what cover you should have for a ltd company? Is 1 million enough cover?
    I will only be working in domestic situations...
    Dan
    PS Hi I'm new here!
  2. kris
    kris Trusted Plumber GSR
    Hi mate, depends on you, i used to have 1mill insurance but if your gonna be joining different bodies like im snipef which require you to have 2mill minimum , and the difference isnt much to purchase,
  3. rpm
    rpm Trusted Plumber
    Welcome along, wouldn`t go ltd straight away, check out recent thread on this topic.
  4. IDCHAPPY
    IDCHAPPY Trusted Plumber GSR
    2 mill
  5. Ch4 plumbing
    Ch4 plumbing Plumber GSR
    If your looking to buy try Intasure, I've just changed to them and found them very competitive.
    • Like Like x 1
  6. PhoenixServices
    PhoenixServices Plumber GSR
    What size properties are you working in? If you start getting a few nice houses you want to make sure you have 5mill really.
    • Like Like x 1
  7. lame plumber
    lame plumber Guest
    London or county council work, 10 -12 million at least, you burn down a terrace and you'll need to emigrate if your 1 million!
    • Like Like x 1
  8. SimonG
    SimonG Trusted Plumber
    I went for 2, only becauee you cant get sfa for a million these days.:)
    • Like Like x 1
  9. Ch4 plumbing
    I've had to upgrade to £10m, like lame says think about what type of work your doing. No point in having £1m if you need more.
    • Like Like x 1
  10. cure1973
    cure1973 Guest
    Thanks for all the replies , I think I will be safe and go for 2 mill then! Got quoted 330 per year with tradesaver not sure if this is too high but I guess I am starting out again after 6 years in oz!
    As to ltd company can you show me the thread? I was ltd in my last business too and didn't ever seem a problem?!
    cheers
  11. newcastle phill
    newcastle phill Guest
    When I lived in hull years ago a business i owned has to have 5 milion cover.
    Can you believe that...5 million in hull.
    What were they expecting me to do...
    ...flatten and rebuild the entire city....TWICE :D
    • Like Like x 7
  12. helpsy
    helpsy Plumber
    £5M cover for me.
  13. Chris F
    Chris F Plumber GSR
    2 million here
  14. gasmanrob
    gasmanrob Plumber GSR
    I had 5 mill as well but don't need any now. 2 mill used to cover me before insurance work said they wanted to see 5
  15. Pipes Plumbing
    Pipes Plumbing Guest
    Minimum £2M... Hetas & Oftec both specify £2M as the minimum level of cover required under their terms. Also depends what sort of work you are doing as to whether you may want / need £5M.
Loading...
Similar Threads - mill insurance Forum Date
Liability insurance - recommendations please Oil and Solid Fuel Forum Wednesday at 4:54 PM
Anyone made multiple claims on insurance in short period? Plumbers Arms Jan 29, 2018
Thread Status:
