Discuss Cant adjust Danfoss pressure am I using correct ports? in the Oil and Solid Fuel Forum area at PlumbersForums.net
I have a SIP space heater and fitted a new matching spec oil nozzle as part of a service on it.
I wanted to check the pump pressure with the new nozzle and its difficult to be sure what port to connect to.
And that these pumps are definitely adjustable! I turned an Allen screw which is not tight so I presume it's the pressure adjuster and after 1 full turn the gauge stayed at 22psi. Spec says 28psi.
Do I keep adjusting or what do you guys think?
Above top screw is the only one which appears adjustable.
Go in the p port
Reply to Cant adjust Danfoss pressure am I using correct ports? in the Oil and Solid Fuel Forum area at PlumbersForums.net
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
Hello all. I'm looking for advice to help my heating engineer fix my problem! He actually installed the unit. It’s a 3 year old oil boiler, a...
5K
