Discuss 15mm glued Plastic pipe & fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Guys
Hoping someone can help. Came across a house in Devon completely plumbed with glued 15mm PVC type hard plastic pipe. (The lady wanted a basin replacing) The tap connectors were brass/copper imbedded in a plastic pipe connector, the pipe and fittings are white, with '15mm made in uk' smudged on the only bit exposed. Question is can you still source parts for this stuff or is it a total plumbing replacement job ?
Cheers in advance
Jono
Hi Paul
Now your asking, I'll try and work out how to attach 3 photos I took on my phone. It might be a while.
Cheers
Jono
Hi Paul
Hope these 3 photos appear, Ill explain further if they do.
Cheers
Jono
Used to work on glued plastic years back, pan in the bot! Needs 24 hrs to set. So be very careful. I would not get involved with it in domestic properties asking for trouble
Sorry Jono I dont recognise it. I am sure a forum member will be along to identify it soon enough :)
Thanks for that, sorry the pictures came out upside down. The iso is on the feed to the plastic wc cistern which I ripped out, I was able to attach a flexi to the existing comp fitting but theres no way I can fit a new basin on the existing pipework.
I suspected this gear was obsolete and I'm guessing its coming to the end of its life.
If she wants this new basin it will have to be a whole house re-plumb ! I might give it a miss.
Cheers
Jono
I would avoid it like the plague. Found houses with it on this local estate. I maybe wrong but I think its called alkathene or something. You would need a pipe specialist to source it for you and its not cheap.
It's not alkathene, one used to be Acorn, can't think of the others, but as above try plumbcenter locally they should be able to source, and they do need 24 ish hours, just make sure it's clean glued, or use a transition coupling to copper if you have somewhere to hide one.
Possibly polyorc or durapipe
Used durapipe around Bracknell, though that was black.
A lot of properties had that and stainless steel.
Try local independent they may be better than national suppliers as buyers understand local issues.
That's handy, never seen an adapter just had to use things like Philmac transition which are massive.
Thanks Chalked
I don't think it's Polyorc as it's 15mm, I wouldn't chance 1/2" compression on old pvc in a hidden void, I think the custard is going to have it all replaced at some time. No point trying to clamp on new to old, all sorts of problems bouncing back to age me even more.
Cheers
Jono
It's actually made by a company no longer around "hunter genova" I work on an estate by me with over 700 houses full of this.
I've been using a coupler by john guest and it's worked fine up to now it's a 15mm to 1/2 inch
May have to order in as not used very much good luck!
Never seen that stuff before but 15mm is 15mm no matter what its made of so just stick an insert in it, whatever type fits best, and shove a pushfit on it. It will be fine.
Either that or rip the lot out.
i know it wont look good but a safe option is a philmac transition coupling if there planning on ripping out later down the line
If it jumps off you wont have much of a leg to stand on though tamz?
That small Plumbers shop Ball-Cock and bits In Bracknell used to do the adaptor's and glue for it Poly-York Have come across some of this in Saltash , Need to be very careful with it go's brittle over the years and starts to snap off .
Theres more chance of me winning the lottery than it ever jumping off.
Its a 15mm pipe made to BS tolerances. Exactly the same diameter pipe down to the baw hair as every other 15mm pipe in the country no matter if it is made by yorkshire, speedfit, hep, polypipe, flowplast or hunter. Its not going to jump off.
It's like putting a wedding ring on an eggshell! It does not have an insert. Was designed for new build, quick install and don't look back! Try telling a nursing home you need to turn the water off for twenty four hours while the glue sets. Before the push on adapter's
Reply to 15mm glued Plastic pipe & fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is very slightly out of shape. It leaked but I added some PFTE tape over the olive and it seems to of done the job. However… I’m tiling the wall and...
A
Hi, I am trying to fit a replacement tap to a mini-sink that's built in to the top of a toilet. The original tap isn't made any more by the manufacturers - the nearest equivalent is apparently this one: GoodHome Lazu 1 lever Mini Contemporary Basin Mono mixer Tap | DIY at B&Q -...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3 or 4 ribs on it). It's painted in a fetching pink/purple colour in the photo. Tried to revive it with some grease before inserting a short length of...
Hi, I have a leak on the live side of one of my rads, in the GF loo. Its a condensing combi system, the house is only 5 years old, so fairly new. The leak is at the bottom compression fitting on the lockshield rad valve. The rad is a chromed steel towel rail, and the valve is brass/copper, the...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems to be slightly smaller than 22 mm compression fitting and when I tighten the compression nut the whole fitting is easily sliding off the pipe and...
