- Messages
- 59
Hi all.
I just wanted to know what effect, if any, it will have on my combi heating system replacing some of the 10mm pipes to my rads with 15mm?
Its a bungalow and the boiler is piped up to span most of the loft in 22mm. This is then stepped to 15mm and then to 10mm for the drops down to the rads.
Previous owner buried the 10mm copper pipe in the plaster with no plastic protective wrap so I am keen to remove them asap as we are having most rooms replastered anyway.
There are two rads in the living room and one in the hall with buried 10mm plastic pipe which will not be replaced. Also there are three more in trunking mounted 10mm copper that will stay.
I want to replace some of the 10mm drops with 15mm chrome surface mounted as i have already done in the kitchen. All heating is working fine at the moment with the kitchen in 15mm but i wanted to double check if replacing more of the 10mm with 15mm wether or not it would effect the performance of the rest of the system that is still 10mm? I hope this makes sense.
Cheers
Cheers
