Discuss 24 RI CH comes on when water on. Possible programmer fault also in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi everyone
Been a while, hope everyone is well.
Been to a job tonight, if hw on rads get hot also. Ch 2 port seized open. Lever on valve permanently slack.
24 RI
Another issue seems to be programmer might be working intermittently. Even with ch and hw turned off at programmer, boiler fired up. What else could it be if not programmer?
The 2 port. Use your multimeter and chase the voltage to see where its coming from causing the boiler to fire. Sounds like a zone valve fault to me though.
Thanks the ch 2 port has definitely gone I know that much. Hot water coming through as soon as hw turned on.
Thanks for confirming for me. I was starting to over think things as usual and looking for another fault.
The 2 port that needs changing is a myson. 4 wires.
Is this an easy swap for a danfoss or any other.
Yeah only difference would be a earth if you change to a metal head ie Honeywell
Only one I could get was a Drayton, is there any difference to the wiring? Thanks
It's 28mm, where does the white go?
Edit: from what I can see it goes in with the live? Is that correct?
Edit again: having another look it's in a terminal by itself as it becomes live when the valve close.
sorry just seen its a 28mm
its like the grey wire
so just make it safe dont need it
Glad that the lads could help. Sorry I was not around. Been away for a few days.
Reply to 24 RI CH comes on when water on. Possible programmer fault also in the Plumbing Jobs | The Job-board area at PlumbersForums.net
