Discuss 3/4 bsp to 22mm fittings in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. Bushman
    Bushman New Member
    Just wondering how I can go from a 3/4 bsp ball valve female to a 22mm compression fitting male.
    I’ll be visiting some plumbers merchant today would be handy to know what to look out for.
    Thanks in advance.
  2. Last Plumber
    Last Plumber Plumber GSR
    With a 3/4" male iron to 22mm Compression fitting. You can get them straight or bent.
  3. oz-plumber
    oz-plumber Plumber
    Just ask / tell them what you need - standard fitting.
  4. Bushman
    Bushman New Member
    All they seem to have are couplers... maybe I’m not explaining myself well.
    One sides a
    3/4 bsp isolation 1/4 turn valve
    the others a motorised valve with a 22mm compression fitting
  5. ShaunCorbs
    3/4 male iron to 22mm and short bit of pipe and straight into your port valve
    But you do need space to do that
  6. Bushman
    Bushman New Member
    I thought that but the space is a bit tight. I would need to remove the isolation valve to make that work, right now the isolation valve has no purpose as you still need to drain down the whole system down to change the motorised valves.
  7. ShaunCorbs
    Or change the port valve for a female threaded one and use a nipple in between
  8. Bushman
    Bushman New Member
    I’d prefer to use Honeywell for reliability and the 22mm compression is the best they have that I can fit.
    I actually found a 3/4 bsp port valve no brand on BES that’s half the price of one of the Honeywell’s but how long it’ll last I’ll never know.
    Think I’ll just remove the isolation valve and go from there.
  9. ShaunCorbs
    Honeywell do some female threaded ones also
  10. Bushman
    Bushman New Member
    If you can point me in the right direction I’ll pick one up.
    That would save so much hassle. Couldn’t find it for looking.
  11. ShaunCorbs
    • Agree Agree x 1
  12. Bushman
    Bushman New Member
    Thanks but that’s 1” bsp and 22mm, I’ve managed to find the correct part number for the 3/4” threaded female Honeywell V4043H 1007, just need to find one with quick turn around for delivery or local supplier.
    Much appreciated for steering me this way. Less fiddling around and should be more straight forward swap.
  13. ShaunCorbs
    Sorry was looking at a few
    • Winner Winner x 1
  14. Bushman
    Bushman New Member
    No worries got 2 arriving tomorrow.
  15. Best
    Best Trusted Plumber
    Good luck with the Honeywell valves!
    Sorry to say, unless they have recently been dramatically redesigned inside, their actuators are rubbish nowadays.
Loading...
Similar Threads - 22mm fittings Forum Date
Lead pipes connecting to 22mm copper Plumbing Forum Aug 10, 2018
Are any fittings allowed on mains in before the stopcock? Water Regulations Friday at 11:47 AM
