Discuss 38mm antislip ring pvc compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am replacing the seals on washers on my sink waste trap. Can the 38mm anti slip ring/washer be bought alone as there is nothing wrong with the actual fittings. I can find the rubber seals and I can see 38mm trap washers at Toolstation. Are these right or can red/blue ones be bought?
And why are they red/blue? Do you get hot/cold wastes?
Most traps can have the seals replaced plumbing and heating merchants stock replacements the colour of the plastic type ring is not relative different manufacturers use a mix of materials , cheers kop
Thank you for your reply. I figured to colour was unimportant, just thought as they are supplied coloured that coloured replacements would be easy to find. It seems not. As a DIYer I stick to ScrewFix and ToolStation.
Blue for 1 1/4 Red for 1 1/2 applies to MacAlpine fittings ...regards Turnpin:)
Reply to 38mm antislip ring pvc compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
