Discuss New Worcester Bosch mag filter? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Are these filters not bi directional?
No fit them as the worcester bosch instructions maka in the bottom conection through the filter and out the top . cheers kop
Made by ADEY but you cannot fit a whole bottle of ADEY chemicals into it but you can in a magnaclean pro 2 filter.
I'm not a huge fan if the push fit on the pro 2. Makes it about floppy when installing.
Buying the WB filter alone it's expensive but with a new boiler and adding an extra year warranty make it good value
Don't you use the included brace
If you use the brace it is easy mate
Well you wouldnt bother then harvest stick with the pro 2 fitted with the brace they are a nice bit of kit and we get points towards freebies mine are totalling up nicely, must admit i only put the worcester filter on a worcester boiler cheers kop
To be honest KOP I would fit it if I did worcesters. Was just saying what annoys me about it.
Have to disagree kojax every diagram shows the flow of the system into the bottom connection on the filter and out the top as below
I have to disagree king of wipes, if you read page 2 regarding the system filter, all is explained. You maybe looking at the position regarding an open vent system. The diagram is drawn with the flow in the bottom and out of the top connection just to make the diagram easier to read.
The latest 'cylindrical' version 'New and Improved':
https://www.worcester-bosch.co.uk/support/literature/download/7733600236a
is bi-directional. The previous 'dumpy' version:
https://media.plumbarena.co.uk/uploads/files/2016/07/27/Worcester_System_Filter_Brochure.pdf
is one way, with flow into the lower port and out of the top.
So everybody is right! And everybody is confused by WB using the same name for two different products.
Reply to New Worcester Bosch mag filter? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just had a new Worcester Bosch Greenstar 30Ri fitted with the magnetic filter. When the system is running the boiler is so quiet but there is a...
Oily smell from boiler recently before failed. Great plumber sorted though when opened external baffle at front of sealed flue the internal spring...
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting...
Hello all. During a recent service to a Worcester Bosch Greenstar 36 cdi compact boiler within my property, a filter was removed by the plumber...
hi everyone a local installer has recently quoted me £3,660 for a complete install using the main eco compact 25kw boiler i have also been...
2K
Deleted member 131795
