Discuss A Question about Central Heating Pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
paulfg
my heating system comprises of 9 radiators over 2 floors with a woodburning fireplace/boiler.
My question is the pump is a wilo star RS30/7 which has a head of 7 metres.
When the system was installed the pump was set on the 3rd setting but i have now turned it down to the slowest 1st setting.All the radiators warm up well
Now my question is ,
the pump needs replacing as it is noisy do I really need a 7 metre pump the main pipes are 28mm from the boiler on the ground floor to th roof space then branch into 2 x 22mm with each radiator fed off of the 22mm in 15mm
What is the effect if any of a too big a head pump?
sorry for the ramble
With all due respect to you, it sounds like you need to get a Heating Engineer round to look over it and advise you.
I am not a plumber. If you search for Wilo they have a UK site and they sell both parts as well as refurbishing their pumps. Might be worth a call to them with model number and ask how much to refurbish. You might find it better to either repair the pump or have it refurbished. Obviously you still need a suitably skilled person to drain down, remove pump and then install a refurbished/repaired pump then refill the system with appropriate corrosion inhibitor and bleed the system.
As for the head and the speed the heating engineer originally set they probably knew what was required at the time. I assume you turned it down to speed 1 as it was noisy? Some boilers are supposed to be operated with their pump at speed 3. Mine boilers pump is supposed to be operated at no3 as in manual.
Looking at Wilo pumps they do seem to be very good quality.
Alternatively ask on here if there is anyone in your area who could come and give you a quote to replace the pump with a suitable one.
Reply to A Question about Central Heating Pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t look well piped , kinky in pipes in some places ,some of the rad don’t heat up too well , probably because of the badly piped system, the pipe is all...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the AUTO (adaptive mode) setting on this the new pump or which mode it is best set at (recently had our old 3-speed pump replaced with the above smart...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open vented system to sealed / pressurized system, new pump ( UPS3 Grundfos ) all new plastic pipework ( extending ) the 22mm feed and return pipes so no...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
