Discuss A standard problem. Plastic bath leaking from over head shower. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jimmybrown75
Hi.
I live in east London.... Require a plumber who has experience with sorting out the age old problem of the plastic bath not sealing due to movement. On inspection, I can see it was installed with 4 legs, but no centre base support. I also cannot see any batten running along the wall. The type of seal used is an under tile seal that was tiled over....However it appears water is still leaking past this. The tap end has no under tile seal, but mastic running along. I believe most of the reason I am struggling is because it is a 11 jet whirlpool bath, upstairs on floorboards, I figure if these arnt installed exactly right, even if i get it to seal initially, when I activate the whirlpool, it will shake and cause leaks during my next shower....
Would just like it sorted!
Cheers for your time.
Reply to A standard problem. Plastic bath leaking from over head shower. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys I know this ain't plumbing. But some of you may know. I have a small bathroom but water seems to leak to the kitchen. I realised under the floor tiles one of the floorboards on side of the bath was wet through and almost rotten. So I feel the water has been seeping through that due...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly using perimeter battens for support, I am attempting to install a fancy whirlpool/jacuzzi bath for my son. Plumbing and electrics are sorted but my...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then drip slowly after that...........i put a bucket under the shower head to collect the water for 26 hours the first time.............then 19 hours the...
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge of the cold water pipe and explained that there were two options: 1. Get into the wall with a jackhammer to fix the problem; or 2. Install one of...
