Discuss About plumbing in a washing machine? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Smcart5
Can someone give me a quick lowdown of what i need to plumb in a washing machine?, the fittings etc, i can solder copper and fittings so i should be able to do it, i have tools and am starting to set about getting experience
Do you need hot and cold for washer? for each pipe you will need a T, copper pipe , washer service valve, and for the waste you will need an extension washer sink waste connection
Forget the waste extension, use a washing machine trap with upstand and put it out through the wall if possible, this alternative eliminates the poteneial for horrible gurgling noises when appliance discharges & keeps "your lass" off yer case.!!
Reply to About plumbing in a washing machine? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
