Discuss Acceptable workmanship? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
70c3b358-0c59-4f53-8f7c-7f9780dc326f-jpeg.31512
86fe05cd-1ac9-47b4-b589-44b466f5a534-jpeg.31513
fbf75560-6b6f-426c-b0bf-b1662d5c1982-jpeg.31514
Hi. Still chasing our house builders regarding snagging. We have had a leak through the attic from condensation from the soil pipe. Can anyone tell me if this is acceptable workmanship? The house is one year old. Duct tape holding it together!
Hi
Pics are not working
Use he upload file button below the message box.
It's not the best but that's builders for you
I bet it’s not even held in properly at the top? Mine wasn’t when I moved into a new build. Fitted a giant jubilee clip to it myself in the end.
So why not just go straight up though the roof , is this connected to a ridge vent ?
Thanks for feedback. The home builder is sending an inspector out to examine but I wanted some advice beforehand as they have a habit of trying to assure us that their work is valid. Just waiting on the excuse for this one. I take it the duct tape for this use is not acceptable? It certainly doesn’t look very professional! Is the flexi pipe the correct piping?
Thanks again for all your feedback.
Duct tape not acceptable as not considered a permanant fixing. Ask him if the vent has been air pressure tested to industry standard - 38mbar for 3 minutes - and you'll probably have him confused.
They did this where I used to work only the ducting was around 6 metres long. It filled up with water and then leaked through the ceiling. I removed it and fitted a durgo valve.
Thanks for all this info. Very useful and just what I was looking for. I took some photos today when I was up emptying the water tray AGAIN. This is how it is attached to the roof
Please remember peeps it's rarely the fault of the individual doing the work...
By the time it's subbed out 27 times, the person who ends up doing the work is forced to do it for peanuts a) because there is no money left and b) cos they are desperate to earn and feed their families. This means they'll do what's necessary (take dreadful, in our eyes, shortcuts) to make a small profit.
The real culprits here are the 'system' where no sod takes responsibility but loads & loads take the money and run...
The system is not the culprit...it's the new home owner who is the culprit.
Time and time again we have visitors who have had shoddy work done on new homes - you can't completely blame the system, you have to blame the unskilled, untrained, uncaring, underling that did the work.
How about that person a month or so ago with his bathroom install.
Incorrect falls on drain, incorrect fittings, incorrect alignment of drain junction - and this bloke thought he was a plumber.
We all thought the home owner had done the work himself.
Its harder to do a job wrong then it is to do it right ..this should be taught across all the construction trades . People who take pride in their work do it right first time from what I see in the trades when people hate their job they dont care whats right or wrong just do what they can get away with to cover themselves lready told a few moaning apprentices if they dont like plumbing do something else had some great lads also willing and eager to learn everything from the trade
Totally disagree if you can't do the job properly then move on at the end of the day it's not always down to price there are standards we all need to adhere to and if you can't/don't then you shouldn't be doing this job .There is absolutely no excuse for inferior and shoddy workmanship...ever....brum
I take your point. Doing a bad job lowers the industry standard and is a bit like sawing off the branch on which you're sitting.
Many valid points but the fault in my eyes lies with the inspectors / Nhbc who pass these properties. If they did their job correctly like people buying new properties are led to believe, then the crap workmanship could be eliminated. I carry out works in loads of new properties and from the design in terms of accessibility of serviceable items to the actual workmanship it's a disgrace. On the plus side, it gives me loads of work repairing the faults.
Agree. Abbey Fields estate in Colchester: all new build and, having worked on a couple, I wouldn't buy one myself. Found a 1.5" waste unclipped and shared by bath and basin in new build and running uphill to SVP - need I say more? The other trades seem to have worked to a similar 'high' standard.
Reply to Acceptable workmanship? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This was all then covered with dot and dab. Shown in the picture, red arrow. So the only thing visible now is a round pipe from the wall. We are yet to fit...
We had the bathrooms replaced when we moved in 2 years ago. This involved 2x bathrooms and 1x WC. Within the first few weeks, we noticed leaking from the en-suite down into the reception room and the fitter promptly came and repaired it, it was something to do with the area under the sink. We...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hello, We had an extension built seven years ago. Initially the builders' plumber connected the heating to the house system but this didn't work. The builder got him out again and he created a separate heating circuit from the boiler (ie one circuit for the house, the other for the extension)...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also have an UFH zone in the kitchen. Near the boiler I have 2 port valves which control this part of the system. The boiler has been loosing pressure...
