Discuss Acrylic modern freestanding bath fixing legs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
purchased from plumb centre.. instructions are crap. modern free standing bath any advice how to fix this to floor. There is 5 legs that get get adjusted to 2 mm below the bath with 4 fixing plates that get positioned carefully on to floor but it kinda hard to take accurate measurements because of the shape of the bath. Any other ideas? I was thinking to extend the feet as long as possible then position the bath in place, then draw around the feet. That way I can fix the fixing plates accurate in place. Then get on with the rest of job.
Would this work?.
Does it not come with instructions?
Am I right in thinking you've just got to line up 4 or 5 feet with 4 or 5 'landing points' (bases)?
But are struggling to get them all in place?
Got any pictures?
Yes I got instructions but no very clear per usual. It's a curved bath but it's kinda difficult to get central point for marking.
I'm going to adjust the feet to the highest points then position the bath in place, then by drawing around the feet I'll have pin point marks for the brackets to be screwed down.
I think this makes more sense than what the instructions say.
Reply to Acrylic modern freestanding bath fixing legs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm currently in the middle of first fixing the waste pipe for my freestanding bath. I've created a mock version out of plastic to determine where the waste enters down through the floor - see photo. I was just wondering is there any minimum length the pipe has to run after the trap...
I have a freestanding bath with claw feet. The overflow pipe, low level u bend and waste pipe are all chrome and above floor level. How do I connect this waste pipe to the pipe work under the floor as obviously the floor needs to be finished before the bath is positioned. Thanks Roy
Hi, I've recently ripped out a full bathroom and am replacing it with new everything. The old bath was P shaped with a fixed shower head coming from the wall. I've replaced the mixer shower but the dimensions of the new shower were identical to the old so the pipework was in the correct place...
2K
Hi I wanted some steer from he forum for my set up. 2 storey house now extended on ground and a loft conversion. New plumbing install as of 18months. Worcester bosch 8000 life sysem boiler via natural gas. Time clock with HW / CH split, 7 day digital. 250litre Gledhill Select Indirect...
2K
Hi there, My twist pop-up bath plug isn’t working and when trying to repair I’ve made a few daft decisions which have led me to the position I’m now in. I first of all adjusted the plug itself by lengthening it using the screw underneath. This didn’t work, so I looked at the twist dial. I...
7K
