Discuss Adey magnaclean professional 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
does anyone else think the 'trigger' is the most stupid idea??
Had to remove one to attach my powerflush machine yesterday, admittedly the space was tight.. but push fit over time is always a nightmare to get off.. why put that stupid plastic thing in the way!!!!
its there for a reason :D
tighten the red wheel back on its self (away fro the magna pot)
and then squeeze the "plastic thing" aginst the body to the magna clean and pull, the bottle should remove easy
What he said, it actually makes it quite easy to remove.
Yeah I did that.. wasn't budging.. had to use a screwdriver to push the lugs in on the push fit connectors and pull it back in half millimetre segments lol took a while
thats strange, there wasnt any pressure on it (eg you had removed the cap)
also did you try pushing it forward first, the squeezing locking ring and pulling off?
have had one stuck yet (touch wood)
Yeah I completely emptied the canister, took out the magnet even and tried again. Had to call adey in the end cos I thought I was being an idiot. They said sometimes it does take a 'tug'.. but this thing was like it was nearly seized on.. tried pushing it forward a couple times to see if I'd actually made any progress lol but no.. got it off in the end though and had to grease the o-rings as they wouldn't push back on.
that is a werid one, once you removed it any crud on the brass tails ?
I like these so much that they are all I fit. Not yet had a problem with any, but then never had to take one back out.
I usually fit the older ones.. but from an install point of view I can see why you do
Always fit adey magnaclean 2 where i can never had any issues fitted one yesterday on a combi swap job done .
please say you brought a spark in for the wiring ?
Hooked into what was there shaun sparks has got to wire in the wireless stat will be tidied up and a cupboard built around it was out for a meal last night with friends so was a bit pushed ha ha cheers kop.
Before and after .
Hooked into what was there shaun sparks has got to wire in the wireless stat will be tidied up then out for a meal last night so was a bit pushed ha ha chepeprs kop
so you didnt drill the gland into the plat :)
Will be changed tuesday shaun when reciever is wired in had to use what i had in the van thanks for info cheers kop
Ah thanks @jaydebruyne
Good to know, didn't know that some require it.
I'm sure someone told me this on here.. never read it myself though but I've only fitted Keston/Ideal/Worcester/Vaillant boilers - Combi's can be an instigator of water hammer so I've learned along my travels
So, basically you install a shock arrestor just in case when doing a boiler swap?
You should be proud of that job mate, very neat.
much better :)
Reply to Adey magnaclean professional 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi after some advice. I am buying a property - refurbished - they have put in a kitchen with space for a slimline dishwasher. There is sufficient height and width but the large plastic pipe behind redues the depth to 53cm when most freestanding machines are 60cm. I am worried this will stick out...
Hi everyone, I’m new to the forum and joined specifically to try to get an answer to my question. I have an 88yo mother-in-law who is recently widowed and her 90yo husband who has since passed insisted on doing everything for himself. Nothing wrong with that but now that he has gone my wife...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for heat, the boiler fires up, modulates, but jumps very quickly (about 30 seconds or so from 40'ish all the way to 70, burner disengages putting it the...
Hi, in order to replace the solenoid on my shower I need to take it off the wall (bad shower design). I've got all the electrics disconnected, it's detached from the wall itself and I've unscrewed where the water pipe from the wall connects to the shower inlet (I'm sorry I don't know the right...
Hi, moved into a home a year ago with what is probably an old heating system. There is a gas boiler linking to radiator central heating, and a water tank. Energy company charged an enormous amount for gas last winter (admittedly I hadn't taken regular meter readings so was unaware until a huge...
