Discuss Advice / info needed for soil pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hope someone may be able to help as i'm getting conflicting 'advice'
Does anyone know where i can get 2 x caps to fit the pipe in the pictures attached? one measures approx 6cm and the other 13cm. Recently unearthed this chamber after moving into a new home and finding the spare toilet was taking ages for the water to go down after flushing. After jetting i've been told that this was a system from the late 70's that requires the caps fitting to restore pressure in the pipe. Despite visiting all the usual merchants nobody can find a cap that fits either.
Any help / advice appreciated.
Were the photos after jetting?
Does the larger one have an internal seal, if so this may fit? ;
110mm Socket Plug
Is the smaller threaded outside?
Failing that you may have to remove the Tee and access pipe and replace with new.
110mm Socket Plug
This is after jetting yes.
No thread on the outside of the smaller hole.
Thanks for the link
Cut it out and replace it ,why is it full if its been jetted surely it should flow away my guess theres no fall on the drain run they will be back in no time doing it again ? Kop
Would something like this not work?? Not sure what sizes are available
Reply to Advice / info needed for soil pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
