Discuss Advice needed - boiler water leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there,
I have had a leaking boiler for a few weeks n ow. It is coming from one of the pipes and I wondered if someone could take a look at the photos I have taken and advise if there is anything I can do to rectify it without getting a plumber out? The arrow shows the pipe it is coming from and the circle is where the puddle of water is.
The leak is very intermittent - maybe once a day and produces a small puddle and then stops.
Thanks,
Mike
Sorry to say no
As you need to be gas safe to remove the boilers cover / case even if your not doing anything on the gas side
Please put the cover back on and call a gas safe engy out
Hi Mike,
As said above best to get a GSR engineer out to look at the boiler & get a service carried out as it looks like it has not had one for a while.
For the small cost of a service and rectification of the leak you will have the peace of mind knowing that the boiler has been checked over by a qualified/insured tradesman & any potential visible future problems identified.
The alternative is -
Wing it &
1. Ignore the issue.
2. Try & fix it yourself and potentially cause other issues/component failures in the boiler
OR
3. Try & fix it yourself and risk of CO poisoning/explosion because you didn't really know what you were doing.
I'm not normally a grumpy git.
I don't mean to be overbearing on my comments but all to often been called when someone has tried to DIY the work themselves and come unstuck.
Generally it's expected for me to wave a magic wand and fix all the problems immediately without any other issues & then assume responsibility for any future problems that may arise because i was the last person to work on/touch the boiler.
Best to listen to the advice of the professionals.
You can post in the - I'm looking for and engineeer/plumber & don't forget to include your boiler make/model & location.
Looking for a Heating Engineer? Post Jobs Here
Reply to Advice needed - boiler water leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
Hi. I get a slight leak of water in the bowl. Any advice re the attached please. Thank you in advance
2 of my properties tenants have notified me that their boilers are leaking yellow water, i need someone ASAP since that Rubbish is disgusting and i cant let them live off like that. Water heating is fine tho, i am prepared to pay anything just get here asap post code is TA5
Dany Michael
My son moved to a new build home in Cornwall last November. Yesterday evening he found a quantity of water beneath the Ideal Combi boiler and a steady water drip from the boiler. After clearing up and putting a container beneath the boiler, he went to bed. This morning the water drip had...
I have a leak from my shower, it's coming down into my kitchen. I've had the sealant, waste pipe and tray all checked. I've also had the shower controls checked. Weird thing is the shower leak only happens when there's weight on the shower tray. The shower tray doesn't flex in any way, which is...
