Discuss Advice needed please in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. Stuart Griffiths
    Stuart Griffiths New Member
  2. jtsplumbing
    jtsplumbing Plumber GSR
    Only problems you get when changing shower units is;
    1. what side does cold water connect.
    2. is pipe long enough
    3. is the electric cable long enough.
    Nothing is ever straight forward.
    • Agree Agree x 1
  3. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    This is where your old shower connection are
    And the other picture is the new. Might not be as easy as expected by had to tell without the case off the old shower. If you do take the case off, make sure to turn the power off at the fuse board.
Loading...
Similar Threads - Advice needed please Forum Date
Advice needed please - run water pipes out or in walls ? Plumbing Forum Thursday at 5:12 PM
Help or advice needed! Plumbing Forum Aug 9, 2018
