Discuss advice on ecotecpro24 boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Filippo
Hi there! Three weeks ago an ecotecpro24 was installed in my flat. hot water working fine. When I turn on the central heating the boiler runs for a couple of minutes, but as soon it reaches the set temperature [50 degrees], it switches itself off. Once the burner anti-cycling time is over, it would do so again and agin, without running continuously. Any suggestion? Thanks!!
Best to call back your installer to check it over & if need be they can call the manufacturer, as if you went straight to the manufacturer & it was a system or installation problem you could end up with a bill.
No need to start another thread on this subject!
You have been advised by several of us to call the installer back - unless you fitted it yourself, or a builder mate did it!?
Reply to advice on ecotecpro24 boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
Hi Can you help me determine if my new Navien lcb700 lsx is working as expected? I got the Navien oil boiler installed to replaced an old firebird boiler. The new boiler is a condensing oil boiler and I’m not sure if this is working as expected. I’ve a 300 L water cylinder and after one hour...
2K
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
Last May had a new Greenstar 4000 boiler fitted and only recently started using the heating. Once the set room temperature is reached the boiler modulates (presumably) and stays running for very long periods (many hours) but the circulating water is only luke warm (about 35 degrees) Any heating...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled toilet with a more affordable model. This new toilet is a back-to-wall type featuring a concealed cistern within a separate unit. Since its installation...
