Discuss Advise please - Filling loop passing, replacemet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All
I have a filling loop in one of my properties that has been left connected.
It also looks like the tenant has been filling the system and rounded off one side (CW) off the isolation valve one way valve.
It looks like it is in the open Filling Loop Alexandra St.JPG position but is not turnable (unless i dremel a groove?)
Since i think is a on the mains in, could i just isolate the mains, isolate the CH fill side and fit a new check valve with isolator (if that is what it is called)?
The reason being is the system is contanstly filling very slowly even though bothe valves are closed?
It's hitting 3.2 bar and the PRV is passing.
How do i approach this guys?
Yes its a new one without a doubt , mains off , take the pressure out of the heating system through the heating side of the hose , when it goes to a dribble into a bucket , quick swap over with the new valve and then do the mains side , get it done asap , a boiler constantly over pressurising does not do it any good especially the prv , they arent designed to keep opening.
So all i need is one 15mm isolation valve and one 15mm check valve with an isolator?
Goog thing is that i will have control when draining the CH as the valve is there and is 1m away from a sink.
You can buy a filling loop in one pack. Any plumber's merchant should stock a filling loop kit. Don't buy a "Robokit" as that will have extra parts you won't need, just a standard filling loop in a bag.
Why do most of the filling loops not have an isloator on the check valve? I thought it was regs that you had to have 2 points of isolation?
Looking at this - R24 Filling Loop
Also what is the removable 'plug/bolt' on the check valves?
Double check valve on the mains water supply side ...if you want the full regs I will send you
chapter an verse...I am an expert in pressurised domestic heating systems. centralheatking
Hi All
It looks like it is in the openView attachment 41101 position but is not turnable (unless i dremel a groove?)
Seen this so often in rentals...your system has a small leak and the ballofix has been
switched on and off to its ..death. They are not produced for this purpose. Find the leak
sort the damaged component or pm me for a solution ...centralheatking
The filling loop in your link is fine. The filling loops without an isolating valve are for systems where there is already an isolator present.
The plug is present on what are called "verifiable check valves". It's for proving the non-return is working. If you take the plug out and water keeps coming out of it then the non-return valve has failed, usually by jamming open or because debris/grit has got in the way of it closing.
Hi All
I would just replace the whole loop, maybe minus the iso on the cold supply((if it’s working).
Regards
Could be passing when you look closely at the nrv the slot appears to be in line suggesting its open and passing on the service valve.
Reply to Advise please - Filling loop passing, replacemet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If you are qualified to do a Gas Safety check on a property I assume that entails checking the boiler. If, when checking a Combi, you notice the...
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not...
On my Valliant eco tec boiler the pressure guage is on red when cold . I drain a radiator to correct to pressure and it works fine and stays in...
Oliver1234
O
Hi All, I have a leaking drain valve off the CW inlet on a Range Cylinder. Am I right in thinking I have to empty the Cylinder below the CW inlet...
newbie184
N
In our sealed Megalo system, when hot water tap is used (say in bathroom shower) the megaflo is taking in some fresh water, I guess to compensate...
