Discuss After cleaning bottle trap, water not running away properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Having just replaced my bathroom basin tap, I thought I would check and clean all the outlet fittings and seals, including a plastic bottle trap (don't know what make, but it was from B&Q about 5 years ago). Now, water runs away very, very slowly - just a trickle. Loosening the bottom of the trap a couple of turns lets the water run away quickly.
Something I wonder about is the short, removable pipe inside the trap. With that removed, the water escapes normally. What is the purpose of the pipe?
The basin waste is a clicker type (it's the original). The waste itself appears clear.
Everything has been installed exactly as it was before
I would really appreciate any help
Hi Chas and welcome any chance of a couple of pictures....regards Turnpin:)
Reply to After cleaning bottle trap, water not running away properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a rubber/plastic gasket that seems To fit the trap but with it, I can’t get it to screw and lock back on (has lugs so locks after quarter turn. But...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
N
The Basin bottle trap is in bad condition and begin to loose water due to corrosion (I believe it is lead). May I use pattex putty paste or collak as an emergency solution? How can I loosen the bottle trap nuts? They are so rusty and calcified I am afraid they may break if try to unscrew them...
A while ago I replaced a leaky, corroded sink trap. That all appears to be fine, I can't find any leaks with it, and everything under the sink appears to be consistently dry. The problem I have is that there appears to be a leak where the waste pipe out from the bottle trap meets the wall...
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom, initially thought it was the toilet, but after smelling the bath tub plug hole it appears to be coming from here. I removed the P trap and very little...
