Discuss All house water pump installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jamesey1823
hi
I am looking to fit a all house pump to my gravity system, I already have a pump installed for the shower, pump located at the tank floor level, but want to remove it and connect the shower feeds back into the system without the pump, I am confident on how to do this, however, once this is done, I want to install an all house pump, one other thing my premises is a bungalow, can anyone tell me what pipes I need to connect to to achieve this, I know I need to fit an Essex or Surrey valve
Hope this makes sence
Jamesey
Reply to All house water pump installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One for shower and one for bath. They both work intermittently and I often need to get them started with a magnet! They were new pumps. In the shower the...
Hi, I am currently using a Grundfos Booster Pump. This pump is fed by 2pcs of 1,000 liters water tank. Normally the pump would stop working only when there is no water in the water tank. But, recently for the past week, in the middle of the night, the pump would stop working even though the...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
